Нет связи с LTR11
Доброго времени суток.
Запустил сегодня крейт (LTR-EU-2-5, модуль LTR11), так же запустил L-Graph 2, а он мне выдал сообщение:
Успешно обнаружены и подключены следующие изделия Л-Кард: LTR-EU-2 (2D551734)
Не удалось подключить следующие изделия Л-Кард: LTR11 (5D524759)
Система Windows XP SP3
Данные с LTR Server:
[17.07.13 10:03:10.703] (0) SERVER: Starting up LTR-Server v1.5.3.0 (L-CARD)
[17.07.13 10:03:11.578] (3) CRATE_INIT: Connecting USB crate...
[17.07.13 10:03:11.578] (3) CRATE_INIT: Crate Info:
[17.07.13 10:03:11.578] (3) CRATE_INIT: + PIDString = Crate LTR(HS Mode)
[17.07.13 10:03:11.578] (3) CRATE_INIT: + DeviceName = LTR031
[17.07.13 10:03:11.578] (3) CRATE_INIT: + SerialNumber = 2D551734
[17.07.13 10:03:12.609] (3) CRATE_READ: LTR031 [2D551734]: module configuration updated. mconfig=0003
[17.07.13 10:03:12.609] (3) CRATE_WRITE: LTR031 [2D551734]: sending STOP+RESET+STOP to slot 1
[17.07.13 10:03:12.609] (3) CRATE_WRITE: LTR031 [2D551734]: sending STOP+RESET+STOP to slot 2
[17.07.13 10:03:12.609] (3) CRATE_READ: LTR031 [2D551734]: found new module LTR11 (slot = 2, mid = 0B0B)
[17.07.13 10:03:12.609] (3) CRATE_READ: LTR031 [2D551734]: found new module LTR11 (slot = 1, mid = 0B0B)
[17.07.13 10:03:20.265] (3) CLIENT_CTL: 127.0.0.1 [server control]: Connection started
[17.07.13 10:03:20.265] (3) CLIENT_CTL: 127.0.0.1 [server control]: Connection stopped
[17.07.13 10:03:20.265] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection started
[17.07.13 10:03:20.265] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection started
[17.07.13 10:03:29.484] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection started
[17.07.13 10:03:29.500] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection stopped
[17.07.13 10:03:38.718] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection stopped
[17.07.13 10:03:38.734] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection stopped
[17.07.13 10:03:38.734] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection started
[17.07.13 10:03:38.734] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection started
[17.07.13 10:03:47.953] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection started
[17.07.13 10:03:47.968] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection stopped
[17.07.13 10:03:57.171] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection stopped
[17.07.13 10:03:57.187] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection stopped
[17.07.13 10:03:57.203] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection started
[17.07.13 10:03:57.203] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection started
[17.07.13 10:04:06.437] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection started
[17.07.13 10:04:06.453] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection stopped
[17.07.13 10:04:15.671] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection stopped
Вчера все замечательно работало, а сегодня модули не видит не L-Graph, не PowerGraph
- Инженер-электронщик
- Здесь с 21.04.2014
Re: Нет связи с LTR11
Дмитрий, если кабели от сигнальных разъёмов модулей отключить, поведение меняется?
Как ведёт себя USB-устройство LTR в диспетчере устройств Вашей ОС во время снятия этого лога? В логе уровень детализации поставьте максимальный.
От чего питается LTR-EU-2-5? От сети ~220 В через штатный сетевой адаптер, входящий в комплект?
Кабели отключил, ничего не изменилось.Питается от сети ~220 В через штатный сетевой адаптер, входящий в комплект. Уровень детализации поставил максимальный, вот что отражается в журнале с самого запуска:
[17.07.13 12:58:20.296] (0) SERVER: Starting up LTR-Server v1.5.3.0 (L-CARD)
[17.07.13 12:58:20.312] (4) CRATE_CTL: LTRServiceCrate thread started.
[17.07.13 12:58:20.343] (4) SERVER: UDP auto-discovery mode enabled
[17.07.13 12:58:20.343] (4) CLIENT_CTL: LTRServiceClient thread started.
[17.07.13 12:58:20.375] (4) CLIENT_INIT: Server: Kolomyets [169.254.71.236]
[17.07.13 12:58:20.390] (4) CRATE_CTL: Scanning USB crates
[17.07.13 12:58:20.390] (6) CRATE_CTL: USB device, crate: //?/usb#vid_0471&pid_3131#5&121e99c8&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}, PIDString = Crate LTR(HS Mode)
[17.07.13 12:58:20.390] (5) CRATE_CTL: Found 1 USB crate(s)
[17.07.13 12:58:21.781] (3) CRATE_INIT: Connecting USB crate...
[17.07.13 12:58:21.781] (7) CRATE_INIT: Init USB crate: OpenLDeviceByName() ok
[17.07.13 12:58:21.781] (7) CRATE_INIT: Init USB crate: GetModuleName() ok
[17.07.13 12:58:21.781] (7) CRATE_INIT: Init USB crate: GetModuleDescription() ok
[17.07.13 12:58:21.781] (3) CRATE_INIT: Crate Info:
[17.07.13 12:58:21.781] (3) CRATE_INIT: + PIDString = Crate LTR(HS Mode)
[17.07.13 12:58:21.781] (3) CRATE_INIT: + DeviceName = LTR031
[17.07.13 12:58:21.781] (3) CRATE_INIT: + SerialNumber = 2D551734
[17.07.13 12:58:21.781] (4) CRATE_INIT: + DeviceComment = Broaching Creation Date Jun 21 2011
[17.07.13 12:58:21.781] (4) CRATE_INIT: + BootLoaderVersion = 139.242.28.108
[17.07.13 12:58:21.781] (4) CRATE_INIT: + FirmwareVersion = 2.0.0.0
[17.07.13 12:58:22.781] (7) CRATE_INIT: LoadFPGA() -> ok.
[17.07.13 12:58:22.781] (4) CRATE_INIT: + TTF_FILE = F:/Program Files/L-Card/ltrserver/ltr010v3_0_5.ttf
[17.07.13 12:58:22.781] (4) CRATE_INIT: + FpgaName = LTR-031
[17.07.13 12:58:22.781] (4) CRATE_INIT: + FpgaVersion = 1.0.8.0
[17.07.13 12:58:22.781] (4) CRATE_INIT: + FpgaComment = Прошивка ПЛИС EP1C8 контроллера крейта LTR-EU-2-5. L-CARD
[17.07.13 12:58:22.781] (4) CRATE_INIT: + BaudRate = 0x0000
[17.07.13 12:58:22.828] (3) CRATE_READ: LTR031 [2D551734]: module configuration updated. mconfig=0003
[17.07.13 12:58:22.828] (5) CRATE_INIT: LTR031 [2D551734]: crate service started.
[17.07.13 12:58:22.828] (3) CRATE_WRITE: LTR031 [2D551734]: sending STOP+RESET+STOP to slot 1
[17.07.13 12:58:22.828] (3) CRATE_WRITE: LTR031 [2D551734]: sending STOP+RESET+STOP to slot 2
[17.07.13 12:58:22.828] (3) CRATE_READ: LTR031 [2D551734]: found new module LTR11 (slot = 2, mid = 0B0B)
[17.07.13 12:58:22.828] (3) CRATE_READ: LTR031 [2D551734]: found new module LTR11 (slot = 1, mid = 0B0B)
[17.07.13 12:58:55.093] (3) CLIENT_CTL: 127.0.0.1 [server control]: Connection started
[17.07.13 12:58:55.093] (5) CLIENT_CTL: 127.0.0.1 [server control]: received end-of-connection
[17.07.13 12:58:55.093] (3) CLIENT_CTL: 127.0.0.1 [server control]: Connection stopped
[17.07.13 12:58:55.093] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection started
[17.07.13 12:58:55.109] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection started
[17.07.13 12:58:55.109] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 1]: starting write thread
[17.07.13 12:58:55.109] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 1]: starting read thread
[17.07.13 12:59:04.343] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection started
[17.07.13 12:59:04.343] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 2]: starting read thread
[17.07.13 12:59:04.343] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 2]: starting write thread
[17.07.13 12:59:04.359] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 1]: received end-of-connection
[17.07.13 12:59:04.359] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 1]: stopping write thread
[17.07.13 12:59:04.359] (7) CLIENT_READ: 127.0.0.1 [2D551734 : 1]: wait aborted by client shutdown
[17.07.13 12:59:04.359] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 1]: stopping read thread
[17.07.13 12:59:04.359] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection stopped
[17.07.13 12:59:13.562] (5) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: PutArray addr = 86000009, size = 10
[17.07.13 12:59:13.578] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 2]: received end-of-connection
[17.07.13 12:59:13.578] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 2]: stopping write thread
[17.07.13 12:59:13.578] (7) CLIENT_READ: 127.0.0.1 [2D551734 : 2]: wait aborted by client shutdown
[17.07.13 12:59:13.578] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 2]: stopping read thread
[17.07.13 12:59:13.578] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection stopped
[17.07.13 12:59:13.593] (5) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: received end-of-connection
[17.07.13 12:59:13.593] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection stopped
[17.07.13 12:59:13.593] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection started
[17.07.13 12:59:13.593] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection started
[17.07.13 12:59:13.593] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 1]: starting read thread
[17.07.13 12:59:13.593] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 1]: starting write thread
[17.07.13 12:59:22.812] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection started
[17.07.13 12:59:22.812] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 2]: starting read thread
[17.07.13 12:59:22.812] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 2]: starting write thread
[17.07.13 12:59:22.828] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 1]: received end-of-connection
[17.07.13 12:59:22.828] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 1]: stopping write thread
[17.07.13 12:59:22.828] (7) CLIENT_READ: 127.0.0.1 [2D551734 : 1]: wait aborted by client shutdown
[17.07.13 12:59:22.828] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 1]: stopping read thread
[17.07.13 12:59:22.828] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection stopped
[17.07.13 12:59:32.031] (5) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: received end-of-connection
[17.07.13 12:59:32.031] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection stopped
[17.07.13 12:59:32.046] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 2]: received end-of-connection
[17.07.13 12:59:32.046] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 2]: stopping write thread
[17.07.13 12:59:32.046] (7) CLIENT_READ: 127.0.0.1 [2D551734 : 2]: wait aborted by client shutdown
[17.07.13 12:59:32.046] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 2]: stopping read thread
[17.07.13 12:59:32.046] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection stopped
[17.07.13 12:59:32.062] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: Connection started
[17.07.13 12:59:32.062] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection started
[17.07.13 12:59:32.062] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 1]: starting write thread
[17.07.13 12:59:32.062] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 1]: starting read thread
[17.07.13 12:59:41.296] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection started
[17.07.13 12:59:41.296] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 2]: starting write thread
[17.07.13 12:59:41.296] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 2]: starting read thread
[17.07.13 12:59:41.312] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 1]: received end-of-connection
[17.07.13 12:59:41.312] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 1]: stopping write thread
[17.07.13 12:59:41.312] (7) CLIENT_READ: 127.0.0.1 [2D551734 : 1]: wait aborted by client shutdown
[17.07.13 12:59:41.312] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 1]: stopping read thread
[17.07.13 12:59:41.312] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 1]: Connection stopped
[17.07.13 12:59:50.515] (5) CLIENT_CTL: 127.0.0.1 [2D551734 : 0]: PutArray addr = 86000009, size = 10
[17.07.13 12:59:50.531] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 2]: received end-of-connection
[17.07.13 12:59:50.531] (5) CLIENT_WRITE: 127.0.0.1 [2D551734 : 2]: stopping write thread
[17.07.13 12:59:50.531] (7) CLIENT_READ: 127.0.0.1 [2D551734 : 2]: wait aborted by client shutdown
[17.07.13 12:59:50.531] (5) CLIENT_READ: 127.0.0.1 [2D551734 : 2]: stopping read thread
[17.07.13 12:59:50.531] (3) CLIENT_CTL: 127.0.0.1 [2D551734 : 2]: Connection stopped
По логу сервера все нормально.
LGraph2 не может подключить только один модуль или все?
Можно попробовать запустить LTR11 через UTS (http://www.lcard.ru/download/uts.zip). Как это сделать знаете?
Вы знаете, не совсем. Там к сожалению нет никаких инструкций, у вас случайно не найдется онных?
А Л-Граф не подключает оба модуля.
В UTS интуитивно понятный интерфейс:
Module->Выбираете модуль
Module->Configure (ставите нужные настройки)
Service-> ...(Выбираете виртуальный прибор для работы)
- Сотрудник "Л Кард"
- Здесь с 17.04.2014
LTR Server показывает статистику принятых и переданных слов по каждому слоту. Если выделить нужный слот с LTR11, и посмотреть число переданных и принятых слов (именно в статистике по слоту, а не общее) до запуска LGraph2 и после - то на сколько изменяться?
UTS мне выдает:
Неудается получить конфигурацию модуля
По поводу статистики по слоту:
Число переданных слов: 4
Число принятых слов: 24
Простите, я неправильно написал.
До запуска:
Число переданных слов: 1
Число принятых слов: 0
После запуска:
Число принятых слов: 5
Дмитрий, Вы пишете: "Запустил сегодня крейт (LTR-EU-2-5, модуль LTR11), так же запустил L-Graph 2, а он мне выдал сообщение..." Дмитрий, хорошо бы вспомнить в деталях, что было вчера (какое ПО, работающее с LTR, запускали, какие версии ПО, как и к чему подключали крейт), поскольку вариантов произошедшего у нас всего два: 1. Была программно стёрта EEPROM контроллера AVR в LTR11. 2. На входы LTR11 был подан сильнейший электростатический разряд, который вывел из строя LTR11. Вариант 1 более вероятен. В любом случае, это ремонт в L-Card...
Я использовал тоже самое ПО, что и до этого.
LGraph2 версия 2.34.19
LTR Server v.1.5.3.0
Версия драйвера 6.0.22
И вряд ли я что то смог стереть
Подключал дифференциальный манометр Метран-150 через делитель напряжения, на входе в крейт напряжение 0-1 В, подключал согласно вашему руководству пользователя.
Можно ли с помощью моего компьютера влезть и посмотреть что на этой памяти(EEPROM)сейчас?
А какой смысл удалённого влезания в EEPROM? Нужно проверять и тестировать устройство по полной программе...
По поводу подключения добавлю, что Ваша система уже достаточно не простая, и требует детального разбора (в смысле "разбора полётов") схемы подключения в между устройствами-участниками:
- Компьютер (вопрос: стационарный системный блок с питанием от сети ~220 В ?)
- LTR-EU-2, подсоединённый к компьютеру по USB.
- Манометр Метран-150
- Цепь преобразования выходного тока манометра в напряжение для подачи на LTR11 в LTR-EU-2.
- Источник питания манометра (тип источника питания?)
- Ещё что-то подключалось к LTR-EU-2 ?
Как это всё соединялось, какая удалённость устройств? Нужна подробная электрическая схема. От одной ли фазы сети ~220 В подключали? Как эти устройства были заземлены? Цепь заземления общая? Ещё какие устройства были подключены к этой же цепи заземления? Какие условия эксплуатации?
Я Вам выслал письмо на support@lcard.ru где постарался ответить на ваши вопросы
Дмитрий, я изучил Ваши схемы и, честно говоря, ужаснулся. AGND - это цепь общего провода СИГНАЛЬНОЙ цепи. Цепь AGND должна быть всегда третьим проводом для подключения к общему проводу сигнальной цепи. Вместо этого, у Вас AGND сидит на общей шине заземления всех устройств и непосредственным образом к сигнальной цепи не подключена. Ваше подключение не только неправильно, но и опасно для LTR, поскольку любая импульсная помеха (допустим от включения сетевого питания участвующих устройств, либо электростатическая) оказывается приложенной между входами AGND и X(Y) модуля. Про предельно допустимые напряжения на входах X(Y) относительно AGND читали в Руководстве пользователя?
Дополнительные вопросы:
Блок питания датчиков какого типа? Динейный? Импульсный? Цепь заземления со стороны сети у него есть? Выходы датчика изолированные?
В зависимости от того, имеют ли датчики индивидуальные изолированные источники питания или общий источник, от того, какую схему подключения использовать (см. http://www.metran.ru/netcat_files/973/9 … an_150.pdf ), от того, какие клеммы 1,2,3,4 соединены внутри датчика (или никакие не соединены - об этом я не нашёл информации) можно было бы решить, какую цепь для нескольких датчиков назначить общей (АGND). Далее, в http://www.lcard.ru/download/ltr.pdf на рис.5-8, стр.109 схема подключения "по току" буквально приведена для ЭТОГО случая. Общие правила подключения в LTR см. в п.3.6.6., стр.57. Всю терминологию и принципы подключения см. в развёрнутой статье: http://www.lcard.ru/download/lcardconnects.pdf (Термин AGND объяснён в п.2.1.3)
Т.е. Вы хотите сказать, что таким образом могла сгореть плата?
Блок питания линейный, он заземлен со стороны сети. Выходы развязаны с питанием.
И еще вопрос. Почему в разъёме DB37F две аналоговые земли?
"Т.е. Вы хотите сказать, что таким образом могла сгореть плата"
- Судя по предоставленным данным, других причин выхода из строя не просматривается.
"Блок питания линейный, он заземлен со стороны сети"
- c этого места подробнее, пожалуйста. Третий провод цепи заземления конкретно куда подключён? Тип источника питания?
"Почему в разъёме DB37F две аналоговые земли?"
-Для удобства подключения в целом ряде случаев подключения.
- Сколько датчиков было подключено?
- У каждого датчика свой источник питания или один общий на все?
- Cколько каналов в одном LTR11 было подключено по цепям X и Y?
- Cколько модулей LTR11 было подключено к датчикам (по логу у Вас их два)?
"c этого места подробнее, пожалуйста. Третий провод цепи заземления конкретно куда подключён? Тип источника питания?"
Питание осуществлялось через сеть общего назначения( ~220 В, 50 Гц), заземление осуществлялось через вилку сетевого шнура(третий контакт в розетке)
"Сколько датчиков было подключено?"
Было подключено два датчика
"Cколько каналов в одном LTR11 было подключено по цепям X и Y?"
Всего было подключено 6 каналов.
"Cколько модулей LTR11 было подключено (по логу у Вас их два)?"
Был подключен только один модуль
Скажите, можно ли привезти крейт в вашу фирму для проверки на ремонтопригодность плат?
И другой вопрос, как мог сгореть другой модуль если,я использовал только один?
Дмитрий.
Спалили зарядом изолированной цепи датчика, приложенным между AGND и X(Y). У линейного источника питания датчика может быть большая ёмкость (может быть тысячи пФ) между первичной и вторичной цепью (из-за обмоток трансформатора), эта ёмкость заряжается примерно до половины фазного напряжения. Ну, грубо говоря, Вы взяли ёмкость, зарядили её от сети, о потом приложили между AGND и X(Y). Более того, LTR11 долго держал эти "удары судьбы" (поскольку какое-то время он работал у Вас), но ведь в электросети киловольтовые короткие импульсы - это обычное дело. Ну вот, импульса и дождались, судя по всему...
Передавайте в ремонт в L-Card ЦЕЛИКОМ весь крейт. После такого воздействия нужно безусловно тестировать всю аппаратуру в крейте, даже если что-то не было подключено.
О способе устройства измерительной цепи в Ваших схемах - отдельный вопрос, поскольку по непонятной причине Вы применили делитель 1 кОм/200 Ом в цепи выхода по току датчика. Если выход датчика токовый, то это ещё одна ошибка...
Хорошо(вернее плохо), а как можно осуществить передачу крейта(нужна заявка по почте или достаточно позвонить или сразу приехать?)
