Проблема с подключением LTR модуля
Мурат
10.03.2014 14:12:50
Здравствуйте. LTR Server индикатор зеленый цвет, но оборудование (Дина-3М) не работает, отсутствует связь с ноутбуком.
Запись с журнала сервера.
[07.03.14 12:12:27.378] (0) SERVER: Starting up LTR-Server v1.5.3.0 (L-CARD)
[07.03.14 12:13:17.688] (3) CRATE_INIT: Connecting IP crate 192.168.1.234 ...
[07.03.14 12:13:17.688] (1) CRATE_INIT: [192.168.1.234]: cannot connect to 192.168.1.234: Connect failed (10051)
[07.03.14 12:13:17.688] (3) CRATE_CTL: [192.168.1.234]: crate stopped
[07.03.14 12:13:20.386] (3) CRATE_INIT: Connecting IP crate 192.168.1.234 ...
[07.03.14 12:13:20.386] (1) CRATE_INIT: [192.168.1.234]: cannot connect to 192.168.1.234: Connect failed (10051)
[07.03.14 12:13:20.386] (3) CRATE_CTL: [192.168.1.234]: crate stopped
[07.03.14 12:14:19.745] (3) CRATE_INIT: Connecting IP crate 192.168.1.234 ...
[07.03.14 12:14:20.805] (3) CRATE_INIT: Crate Info:
[07.03.14 12:14:20.805] (3) CRATE_INIT: + Location = 192.168.1.234
[07.03.14 12:14:20.805] (3) CRATE_INIT: + DeviceName = LTR031
[07.03.14 12:14:20.805] (3) CRATE_INIT: + SerialNumber = 2D779451
[07.03.14 12:14:21.008] (3) CRATE_READ: LTR031 [2D779451]: module configuration updated. mconfig=0003
[07.03.14 12:14:21.008] (3) CRATE_WRITE: LTR031 [2D779451]: sending STOP+RESET+STOP to slot 1
[07.03.14 12:14:21.008] (3) CRATE_WRITE: LTR031 [2D779451]: sending STOP+RESET+STOP to slot 2
[07.03.14 12:14:21.008] (3) CRATE_READ: LTR031 [2D779451]: found new module LTR11 (slot = 2, mid = 0B0B)
[07.03.14 12:14:21.008] (3) CRATE_READ: LTR031 [2D779451]: found new module LTR43 (slot = 1, mid = 2B2B)
[07.03.14 12:15:07.542] (3) CLIENT_CTL: 127.0.0.1 [2D779451 : 1]: Connection started
[07.03.14 12:15:08.275] (3) CLIENT_CTL: 127.0.0.1 [2D779451 : 2]: Connection started
[07.03.14 12:16:07.415] (1) CLIENT_WRITE: 127.0.0.1 [2D779451 : 1]: async receive failed (error 10054)
[07.03.14 12:16:07.415] (3) CLIENT_CTL: 127.0.0.1 [2D779451 : 1]: Connection stopped
[07.03.14 12:16:07.415] (1) CLIENT_WRITE: 127.0.0.1 [2D779451 : 2]: async receive failed (error 10054)
[07.03.14 12:16:07.415] (3) CLIENT_CTL: 127.0.0.1 [2D779451 : 2]: Connection stopped
[07.03.14 12:16:46.296] (3) CLIENT_CTL: 127.0.0.1 [2D779451 : 1]: Connection started
[07.03.14 12:16:47.014] (3) CLIENT_CTL: 127.0.0.1 [2D779451 : 2]: Connection started
[07.03.14 12:17:14.142] (1) CLIENT_WRITE: 127.0.0.1 [2D779451 : 1]: async receive failed (error 10054)
[07.03.14 12:17:14.142] (3) CLIENT_CTL: 127.0.0.1 [2D779451 : 1]: Connection stopped
[07.03.14 12:17:14.142] (1) CLIENT_WRITE: 127.0.0.1 [2D779451 : 2]: async receive failed (error 10054)
[07.03.14 12:17:14.142] (3) CLIENT_CTL: 127.0.0.1 [2D779451 : 2]: Connection stopped
[07.03.14 12:18:04.066] (0) SERVER: Server shutting down
[07.03.14 12:18:04.394] (3) CRATE_CTL: LTR031 [2D779451]: crate stopped
Подскажите как решить эту проблему?
11.03.2014 11:10:24
Re: Проблема с подключением LTR модуля
Здравствуйте!
С точки зрения журнала LTRServer/'а в плане связи с крейтом LTR никаких проблем нет, в то время как пользовательское ПО несколько некорректно закрывает соединение с сервером (соответствует строкам async receive failed (error 10054)). Здесь вопрос почему это ПО закрывает соединение... А что Вам ответила поддержка авторов ПО для Дина-3М? есть ли журнал в самом этом ПО? Не совсем понятно, что значит фраза "отсутствует связь с ноутбуком". Тажке интересует история проблемы, работало это оборудование на других ПК или работали ли на этой машине с другими экземплярами оборудования.
Что касается проверки работоспособности оборудования L-Card, то для этих целей преодоставляется программа UTS, которую Вы можете скачать http://www.lcard.ru/download/uts.zip (должны быть установлены также библиотеки http://www.lcard.ru/download/ltrdll.exe).
11.03.2014 12:06:21
При тестировании с помощью UTS, как минимум, нужно проверить, что сбор данных с модулей LTR11 и LTR43 проходит нормально (при ошибках сама программа UTS об этом сообщит), а, как максимум, нужно проверить, что величина измеренного напряжения на входах LTR11 (и считанные логические уровни LTR43) соответствует норме для аппаратуры Дина-3М, а также, что порты LTR43, настроенные на выход, правильно работают в аппаратуре Дина-3М.  По логике, на все эти вопросы должна ответить техподдержка Дина-3М и, в случае обнаружении неисправности в аппаратуре L-Card, обратиться к нам.
