Проблема c GET_MODULE_DESCRIPTION в Win7 и VS2008
DimS
04.06.2012 00:14:31
При работе с E14-140 в Windows7 и Microsoft Visual Studio 2008
возникла проблема с функцией GET_MODULE_DESCRIPTION(&md)
структура md не заполняется.
вот код
bool CLCardController::Create(const char* serial)
    ASSERT(!m_pE140);
    m_pE140 = static_cast<ILE140*>(CreateInstance("e140"));
    if (!m_pE140)
        return false;
    for (int i = 0; i < 0xFFFF; i++)
        if (!m_pE140->OpenLDevice((WORD)i))
            continue;
        MODULE_DESCR_E140 md;
        CString My_string = GetSerialNumber(md);
        if (m_pE140->GET_MODULE_DESCR(&md) && !strcmp(GetSerialNumber(md), serial))  // ошибка
            return true;
        m_pE140->CloseLDevice();
    m_pE140->ReleaseLDevice();
    m_pE140 = NULL;
    return false;
при ошибке в режиме отладчика меня выкидывает в код Asembler/'a
Вот код:
        page    ,132
        title   chkstk - C stack checking routine
;chkstk.asm - C stack checking routine
;       Copyright (c) Microsoft Corporation. All rights reserved.
;Purpose:
;       Provides support for automatic stack checking in C procedures
;       when stack checking is enabled.
.xlist
        include cruntime.inc
.list
; size of a page of memory
_PAGESIZE_      equ     1000h
        CODESEG
page
;_chkstk - check stack upon procedure entry
;Purpose:
;       Provide stack checking on procedure entry. Method is to simply probe
;       each page of memory required for the stack in descending order. This
;       causes the necessary pages of memory to be allocated via the guard
;       page scheme, if possible. In the event of failure, the OS raises the
;       _XCPT_UNABLE_TO_GROW_STACK exception.
;       NOTE:  Currently, the (EAX < _PAGESIZE_) code path falls through
;       to the "lastpage" label of the (EAX >= _PAGESIZE_) code path.  This
;       is small; a minor speed optimization would be to special case
;       this up top.  This would avoid the painful save/restore of
;       ecx and would shorten the code path by 4-6 instructions.
;Entry:
;       EAX = size of local frame
;Exit:
;       ESP = new stackframe, if successful
;Uses:
;       EAX
;Exceptions:
;       _XCPT_GUARD_PAGE_VIOLATION - May be raised on a page probe. NEVER TRAP
;                                    THIS!!!! It is used by the OS to grow the
;                                    stack on demand.
;       _XCPT_UNABLE_TO_GROW_STACK - The stack cannot be grown. More precisely,
;                                    the attempt by the OS memory manager to
;                                    allocate another guard page in response
;                                    to a _XCPT_GUARD_PAGE_VIOLATION has
;                                    failed.
public  _alloca_probe
_chkstk proc
_alloca_probe    =  _chkstk
        push    ecx
; Calculate new TOS.
        lea     ecx, [esp] + 8 - 4      ; TOS before entering function + size for ret value
        sub     ecx, eax                ; new TOS
; Handle allocation size that results in wraparound.
; Wraparound will result in StackOverflow exception.
        sbb     eax, eax                ; 0 if CF==0, ~0 if CF==1
        not     eax                     ; ~0 if TOS did not wrapped around, 0 otherwise
        and     ecx, eax                ; set to 0 if wraparound
        mov     eax, esp                ; current TOS
        and     eax, not ( _PAGESIZE_ - 1) ; Round down to current page boundary
// в данном цикле возникает ошибка:
// начало--------------------------------------------------------
cs10:
        cmp     ecx, eax                ; Is new TOS
        jb      short cs20              ; in probed page?
        mov     eax, ecx                ; yes.
        pop     ecx
        xchg    esp, eax                ; update esp
        mov     eax, dword ptr [eax]    ; get return address
        mov     dword ptr [esp], eax    ; and put it at new TOS
        ret
// Конец--------------------------------------------------------
; Find next lower page and probe
cs20:
        sub     eax, _PAGESIZE_         ; decrease by PAGESIZE
        test    dword ptr [eax],eax     ; probe page.
        jmp     short cs10
_chkstk endp
        end
04.06.2012 10:42:52
Re: Проблема c GET_MODULE_DESCRIPTION в Win7 и VS2008
1. А штатные примеры из директории /USB/Lusbapi/E14-140/Examples/ работают нормально?
2. А какая именно функция вызывает ошибку GET_MODULE_DESCR() или GetSerialNumber()?
04.06.2012 10:51:53
Здесь с 18.04.2014
Что за версия lusbapi у Вас?
В коде методы CreateInstance, ReleaseLDevice, GET_MODULE_DESCR - это, кажется, что-то чуть ли не 2.x ?
(В акутальной ветке lusbapi 3.x - CreateLInstance, ReleaseLInstance, GET_MODULE_DESCRIPTION.)
1) Соответствует ли версия lusbapi.h файлу lusbapi.dll? Если у Вас новая DLL, а в проекте старый h-файл, то работать не будет ничего совсем.
(Поэтому проверка на GetDllVersion() == CURRENT_VERSION_LUSBAPI на самом деле обязательна, а файл lusbapi.dll надо класть в каталог с exe основной программы и носить с собой)
2) Если версия DLL правильная, то, может быть, дело в выравнивании структур или чем-то подобном. Но тут надо сразу решить, будете ли переходть на актуальную версию библиотеки и драйвера http://www.lcard.ru/download/ , а потом уже отлаживаться.
DimS
04.06.2012 11:55:42
Ошибка в функции GET_MODULE_DESCRIPTION().
проверил DLL & h-файл версии одинаковые 3.3.
04.06.2012 12:17:40
А как штатные-то примеры? Работают?
04.06.2012 13:08:32
Здесь с 18.04.2014
Как так может быть? В версии 3.3 нет методов ReleaseLDevice и GET_MODULE_DESCR.
Этот код просто не должен скомпилироваться с .h файлами от lusbapi 3.3.
Проверьте еще раз все include-файлы, пожалуйста, и из каких каталогов они берутся. Наверняка где-то затесался старый .h-ник, ну просто я почти в этом уверен.
DimS
05.06.2012 11:30:58
спасибо за помощь, вроде заработало.
