проблема с Е20-10
Антон
09.10.2010 11:45:30
проблема с Е20-10
1. Создаю объект класса E20-10:
TE20_10::TE20_10(string logFileName)
    LUnknown* pIUnknown;
    ULONG Err = L_SUCCESS,Err1;
    PLATA_DESCR_U2 pd;
    SLOT_PAR sl;
    ULONG slot=0;
    FILE *fplogFileName;
    Process_Init = true;
    fdata = NULL;
    MSegmentSize = DEFAULT_SEGMENT_SIZE;//=25000000
    MappedFileName = DEFAULT_MAPPEDFILENAME;
    //Открываем Log file
    out.open(logFileName.c_str());
    if (!out) throw "Can//'t open file " + logFileName;
    //Загружаем dll библиотеку
    CallCreateInstance("lcomp.dll");
    //Сканируем порты ввода вывода и находим на одном из них необходимый модуль
    while(1)
        pIUnknown = CreateInstance(slot); // slot 0
        if(pIUnknown == NULL) {Err = GetLastError(); break;}
        if(!SUCCEEDED(hr)) { Err1 = 1; break;}
        pIUnknown->Release();
        Err1 = (ULONG)pI->OpenLDevice();
        pI->GetSlotParam(&sl);
        if(sl.BoardType == E2010)
            E20_10BiosFile = "E2010";
            Err1 =0; break;
        else if(sl.BoardType == E2010B)
            E20_10BiosFile = "e2010m";
            Err1 =0; break;
        pI->CloseLDevice();
        slot++;
    if(Err)
        MessageBox(NULL,MES_E2010_SEARCHLCARDFALED,MES_ERROR,MB_OK|MB_ICONERROR);
        out << "No L-Card boards on this computer" << endl;
        Process_Init = false;
    if(Err1)
        if(Err1==1)
            MessageBox(NULL,MES_E2010_GETINTERFASEFALED,MES_ERROR,MB_OK|MB_ICONERROR);
            out << "Failed get interface." << endl;
        if(Err1==2)
            MessageBox(NULL,MES_E2010_SEARCHE2010FALED,MES_ERROR,MB_OK|MB_ICONERROR);
            out << "No E2010 boards on this computer" << endl;
   else
        out << "Found first E2010 board at LDev" << slot << "..." << endl;
    //Получаем интерфейс модуля
    if(Process_Init)
    {   pI->CloseLDevice();
        out << "Get IDaqLDevice interface" << endl;
        Err = pIUnknown->QueryInterface(IID_ILDEV,(void**)&pI);
        if(!SUCCEEDED(Err))
            out << "Get IDaqLDevice failed" << endl;
    //Получаем доступ к устройству
    if(Process_Init)
        Err = (ULONG) pI->OpenLDevice();
        out << "OpenLDevice Handle " << hex << Err << endl;
        if(Err==ULONG(INVALID_HANDLE_VALUE))
            out << "OpenLDevice faled" << endl;
    //Загружаем прошивку ДСП
    if(Process_Init)
        Err = pI->LoadBios(E20_10BiosFile.c_str());
        out << "LoadBios status    " << L_RESULT(Err).c_str() << endl;
        if(Err==L_ERROR)
            out << "LoadBios faled" << endl;
    //Тестируем плату
    if(Process_Init)
        Err = pI->PlataTest();
        out << "Plata test         " << L_RESULT(Err).c_str() << endl;
        if(Err==L_ERROR)
            out << "PlataTest faled" << endl;
    //Получаем все данные модуля
    if(Process_Init)
        out << endl << "Slot parameters" << endl;
        Err = pI->GetSlotParam(&sl);
        if(Err==L_ERROR)
            out << "GetSlotParams faled" << endl;
        else
            out << "Base    " << hex << sl.Base << endl;
            out << "BaseL   " << sl.BaseL << endl;
            out << "Mem     " << sl.Mem << endl;
            out << "MemL    " << sl.MemL << endl;
            out << "Type    " << sl.BoardType << endl;
            out << "DSPType " << sl.DSPType << endl;
            out << "Irq     " << sl.Irq << endl;
    //Считываем данные из flash-памяти
    if(Process_Init)
        out << endl << "Read FLASH" << endl;
        Err = pI->ReadPlataDescr(&pd); // fill up properties
        if(Err==L_ERROR)
            out << "ReadPlataDescr faled" << endl;
        else
            out << "SerNum       " << pd.t6.SerNum << endl;
            out << "BrdName      " << pd.t6.BrdName << endl;
            out << "Rev          " << pd.t6.Rev << endl;
            out << "DspType      " << pd.t6.DspType << endl;
            out << "IsDacPresent " << pd.t6.IsDacPresent << endl;
            out << "Quartz       " << dec << pd.t1.Quartz << endl;
            //Заполняем массив калибровочных коэффициентов
            for(int i=0;i<=4;i++)
                for(int j=0;j<=3;j++)
                    ZeroOffsetCoeff[i][j] = pd.t6.KoefADC[i*3+j];
                    ScaleCoeff[i][j] = pd.t6.KoefADC[12+i*3+j];
            out << "Offset coefficients:" << endl;
            out << ZeroOffsetCoeff[0][0] << "//t" << ZeroOffsetCoeff[1][0] << "//t" << ZeroOffsetCoeff[2][0] << "//t" << ZeroOffsetCoeff[3][0] << endl;
            out << ZeroOffsetCoeff[0][1] << "//t" << ZeroOffsetCoeff[1][1] << "//t" << ZeroOffsetCoeff[2][1] << "//t" << ZeroOffsetCoeff[3][1] << endl;
            out << ZeroOffsetCoeff[0][2] << "//t" << ZeroOffsetCoeff[1][2] << "//t" << ZeroOffsetCoeff[2][2] << "//t" << ZeroOffsetCoeff[3][2] << endl;
            out << "Scale coefficients:" << endl;
            out << ScaleCoeff[0][0] << "//t" << ScaleCoeff[1][0] << "//t" << ScaleCoeff[2][0] << "//t" << ScaleCoeff[3][0] << endl;
            out << ScaleCoeff[0][1] << "//t" << ScaleCoeff[1][1] << "//t" << ScaleCoeff[2][1] << "//t" << ScaleCoeff[3][1] << endl;
            out << ScaleCoeff[0][2] << "//t" << ScaleCoeff[1][2] << "//t" << ScaleCoeff[2][2] << "//t" << ScaleCoeff[3][2] << endl << endl;
    //Если что-то не получилось, то говорим об этом
    if(!Process_Init)
        MessageBox(NULL,MES_E2010_OPENFALED,MES_ERROR,MB_OK | MB_ICONERROR);
все нормально проходит.
Далее запускаем измерения:
bool TE20_10::Oscilloscope(void)
    AnalyseConstLevel = false;
    //Проверяем что инициализация прошла успешно
    if(!Process_Init)
        MessageBox(NULL,MES_E2010_DEVICENOTREADY,MES_ERROR,MB_OK | MB_ICONERROR);
        return false;
    //Считаем сколько каналов мы используем
    int NumChanel = GetNumberOfChanel();
    /*Вычисляем сколько отсчетом мы хотим
    int Multiplier = GetMultiplier();
    ULONG Err;
    //Рассчитваем параметры сбора данных
    //Общее количество точек, которое мы хотим получить
    unsigned long TotalNumberOfPoints = BlockSize*Multiplier*NumChanel*NumberOfBlocks;
    unsigned long TotalNumberOfPages;
    ADC_PAR adcPar;
    DWORD tm;
    int MaxNumOfPages = 129;
    do{
    //Расcчитваем количество страниц, требующихся для получения такого количества точек
    TotalNumberOfPages = TotalNumberOfPoints/IrqStep + (TotalNumberOfPoints%IrqStep==0?0:1);
    //Теперь стремимся минимизировать количество лишних точек путем оптимального выбора числа страниц
    //Ищем количество страниц в буффере при котором количество лишних точек минимально
    UINT AdditionalMinimum = TotalNumberOfPages,NumOfPages = 32;
    for(int i=32;i<MaxNumOfPages;i++)
        if(AdditionalMinimum>=(TotalNumberOfPages/i + (TotalNumberOfPages%i==0?0:1))*i-TotalNumberOfPages)
            AdditionalMinimum = (TotalNumberOfPages/i + (TotalNumberOfPages%i==0?0:1))*i-TotalNumberOfPages;
            NumOfPages = i;
    pages = NumOfPages;
    multi = (TotalNumberOfPages + AdditionalMinimum)/pages*2;
    if(multi<2) multi=1;
    tm = 512000;  // сколько отсчетов мы хотим (размер буффера ПК)
    Err = pI->RequestBufferStream(&tm,L_STREAM_ADC);
    if(Err==L_ERROR)
        out << "Can//'t allocate memory! " << endl;
        return false;
    out << "Allocated memory size(word): " << tm << endl;
    // настроили параметрыы сбора
    adcPar.t2.s_Type = L_ADC_PARAM;
    adcPar.t2.AutoInit = 1;
    adcPar.t2.dRate = ADCFrequency;
    adcPar.t2.dKadr = 0.0;
    adcPar.t2.SynchroType = 0x01;
    adcPar.t2.AdcIMask = SIG_0|SIG_1|SIG_2|SIG_3;
    adcPar.t2.NCh = NumChanel;
    NumChanel=0;
    for(int i=0;i<TOTAL_NUMBER_CHANEL;i++)
        if(Chanels[i])
            adcPar.t2.Chn[NumChanel] = i;
            NumChanel++;
            //Дальше устанавливаем необходимый диапазон входного сигнала
            if(i==0 && ChanelsAmplification[i])//<-- 1-й канал
                adcPar.t2.AdcIMask |= (ChanelsAmplification[i]==1?V10_0:V03_0);
            if(i==1 && ChanelsAmplification[i])//<-- 2-й канал
                adcPar.t2.AdcIMask |= (ChanelsAmplification[i]==1?V10_1:V03_1);
            if(i==2 && ChanelsAmplification[i])//<-- 3-й канал
                adcPar.t2.AdcIMask |= (ChanelsAmplification[i]==1?V10_2:V03_2);
            if(i==3 && ChanelsAmplification[i])//<-- 4-й канал
                adcPar.t2.AdcIMask |= (ChanelsAmplification[i]==1?V10_3:V03_3);
    adcPar.t2.FIFO = FIFO;
    adcPar.t2.IrqStep = IrqStep;
    adcPar.t2.Pages = pages;
    adcPar.t2.IrqEna = 1;
    adcPar.t2.AdcEna = 1;
    //Заполняем параметры ввода
    Err = pI->FillDAQparameters(&adcPar.t2);
    if(Err==L_ERROR)
        out << "FillDAQparameters error! " << endl;
        return false;
    //Записываем параметры ввода в память АЦП
    Err = pI->SetParametersStream(&adcPar.t2, &tm, (void **)&data, (void **)&sync,L_STREAM_ADC);
    if(Err==L_ERROR)
        out << "SetParametersStream error! " << endl;
        return false;
    MaxNumOfPages = pages;
} while(adcPar.t2.Pages < pages);
    out << "Buffer size(word): " << tm << endl;
    out << "Pages:             " << adcPar.t2.Pages << endl;
    out << "IrqStep:           " << adcPar.t2.IrqStep << endl;
    out << "FIFO:              " << adcPar.t2.FIFO << endl;
    out << "Rate:              " << adcPar.t2.dRate << endl;
    DataStep = adcPar.t2.dRate/(Multiplier*NumChanel);
    IrqStep = adcPar.t2.IrqStep;
    pages = adcPar.t2.Pages;
    out << "Started ..." << endl;
    // Запоминаем размер половинки буффера
    HalfBuffer = pages*IrqStep/2;
    // Создаем файл (для того чтобы не возникало переполнения виртуальной памяти процесса будем выделять
    //максимум 500 мегабайт памяти)
    fsize = multi*pages*IrqStep/2; // размер файла, деленный на 2 потому что собираем половинками буффера
    hFile=CreateFile(MappedFileName.c_str(),GENERIC_READ|GENERIC_WRITE,FILE_SHARE_WRITE,
                               NULL,CREATE_ALWAYS,FILE_FLAG_RANDOM_ACCESS,NULL);
    if(hFile==INVALID_HANDLE_VALUE)
        MessageBox(0,MES_FILEOPENERROR,MES_ERROR,MB_OK|MB_ICONERROR);
        out << "File open error" << endl;
        return false;
    //Выделяем область памяти
    hMap=CreateFileMapping(hFile,NULL,PAGE_READWRITE,0,(fsize>MainForm->E20_10->MSegmentSize?2*MainForm->E20_10->MSegmentSize:fsize*2),NULL);
    if(hMap==NULL)
        MessageBox(0,MES_FILEMAPERROR,MES_ERROR,MB_OK|MB_ICONERROR);
        out << "File mapping error" << endl;
        return false;
    else
        out << "Mapped file size (word):" << fsize<< endl;
    //Проецируем файл на выделенную область памяти
    fdata=(WORD *)MapViewOfFile(hMap,FILE_MAP_WRITE,0,0,0);
    if(!fdata)
        ShowMessage(SysErrorMessage(GetLastError()));
    complete=0;
    pI->EnableCorrection();
// Инициализируем внутренние переменные драйвера
    Err = pI->InitStartLDevice();
    if(Err==L_ERROR)
        out << "InitStartLDevice error! " << endl;
        return false;
// Запускаем сбор в драйвере
    Err = status=pI->StartLDevice();
    if(Err==L_ERROR)
        out << "StartLDevice error! " << endl;
        return false;
// Создаем и запускаем поток сбора данных
    hThread=CreateThread(0,0x2000,ServiceThread,0,0,&Tid);
    return true;//Закончили
Поток сбора данных имеет следующий вид:
// Поток в котором осуществляется сбор данных
#pragma optimize ("", off)
ULONG WINAPI ServiceThread(PVOID)
    ULONG halfbuffer = MainForm->E20_10->HalfBuffer;             // Собираем половинками кольцевого буфера
    ULONG fl2,fl1 = fl2 = (*sync<=halfbuffer)? 0:1; // Настроили флаги
    USHORT *tmp, *tmp1;
    MainForm->E20_10->MSegmentSizeUsage = 0;
    MainForm->E20_10->MSegment = 0;
    for (currMeasure = 0;currMeasure < MainForm->E20_10->multi;currMeasure++)// Цикл по необходимомму количеству половинок
        //Следим за сегментированием памяти
        if(halfbuffer*(currMeasure+1) - MainForm->E20_10->MSegment*MainForm->E20_10->MSegmentSizeUsage > MainForm->E20_10->MSegmentSize)
        {   if(MainForm->E20_10->MSegment==0)   MainForm->E20_10->MSegmentSizeUsage = halfbuffer*currMeasure;
            MainForm->E20_10->MSegment++;
         //WaitForSingleObject(hEventData,INFINITE);
         while(fl2==fl1) fl2=(*sync<=halfbuffer)? 0:1; // Ждем заполнения половинки буфера
        tmp=MainForm->E20_10->fdata+(halfbuffer*currMeasure -MainForm->E20_10->MSegment*MainForm->E20_10->MSegmentSizeUsage);                    // Настраиваем указатель в файле
        tmp1=data+(halfbuffer*fl1);                  // Настраиваем указатель в кольцевом буфере
        memcpy(tmp,tmp1,halfbuffer*sizeof(USHORT));// Записываем данные в файл
        fl1=(*sync<=halfbuffer)? 0:1;                // Обновляем флаг
        Sleep(2);                                    // если собираем медленно то можно и спать больше
        if(StopMeasurement)
            break;
   //Sleep(300);
   complete=1;                                     // Мы завершили сбор данных
   return 0;                                          // Вышли
#pragma optimize ("", on)
если я запускаю сбор большой партии данных, то все нормально работает при любом соcтоянии входов и вопросов нет.
Проблема возникает, если я запускаю по таймеру например раз в 1 секунду сбор небольших партий данных например реализация длительностью 0.2 сек с частотой АЦП 1000кГц. В этом случае, если на АЦП не подключен никакой сигнал, то все тоже нормально работает и данные идут, в случае же если сигнал подключен то получаю 1-2 измерения и связьс АЦП пропадает (поток сбора данных никак не может дождаться прихода очередной партии данных). Аналогичный алгоритм с той же последней версией драйверов (конец мая 2010 г.) с платой L780 прекрасно работает в любом режиме. Данная проблема наблюдалась на нескольких E20-10 на разных компьютерах как под управлением Windows7, так и Windows XP.
Функция запускающая измерения по таймеру:
void __fastcall TOscilloscopeForm::OscilloscopeTimerTimer(TObject *Sender)
    if(AllowTimerUpdate)
        AllowTimerUpdate = false;
        bool OscilloscopeResult;
        OscilloscopeResult = Device->Oscilloscope();
        //Проверяем что не было сбоев оборудования
        if(!OscilloscopeResult)
           OscilloscopeForm->Close();
            return;
        // Получаем необходимые данные и создаем необходимые массивы
        //Если все нормально, то ждем пока закончатся измерения
        while(!complete){};
        Device->StopDevice();
    /*перенос данных во временные массивы для обработки
        Device->FreeBuffers();
    /*отображение данных
        AllowTimerUpdate = true;
// Еще два метода класса E20-10==Device
void TE20_10::FreeBuffers(void)
    if(fdata)    UnmapViewOfFile(fdata);
    if(hMap)
        if(CloseHandle(hMap))   hMap = NULL;
   // освободим идентификатор файла данных
    if(hFile)
        if(CloseHandle(hFile))  hFile = NULL;
void TE20_10::StopDevice(void)
    ULONG Err;
    if(Process_Init)
        Err = pI->StopLDevice(); // Остановили сбор
        if(Err==L_ERROR)
        out << "StopLDevice error!" << endl;
        if(hEventData) CloseHandle(hEventData);
    CloseHandle(hThread);
   // out << "StartLDevice returned " <<  (status ? "TRUE":"FALSE") << endl;
09.10.2010 16:03:14
Re: проблема с Е20-10
<<если на АЦП не подключен никакой сигнал, то все тоже нормально работает и данные идут, в случае же если сигнал подключен то получаю 1-2 измерения и связьс АЦП пропадает>>
- это очень похоже на проблему подключения. На всякий случай проверьте под Lgraph или Lgraph2 с подключенными источниками сигналов. Если эффект пропадания связи повторится (в диспетчере устройств E20-10 исчезает или приобретает статус ошибки), то будем разбираться с подключением. В частности, сбой работы USB вероятен, если цепи заземления источников сигналов не связаны с корпусом компьютера.
09.10.2010 16:11:28
Опишите, пожалуйста, что из себя представляют источники сигналов, с чем они соединены, что именно и каким образом заземлено.
Антон
09.10.2010 19:40:16
реальный сигнал представляет собой дифференциальный выход усилителя. Усилитель усиливает сигнал, поступающий с фотоприемника. Используется только 1-й канал АЦП. Но насколько я помню проблема возникала и когда я подавал на АЦП синусоиду, сгенерированную звуковой картой компьютера (ноутбука, если точнее). Насчет того что происходит в Lgraph, смогу посмотреть ближе к середине недели...
Но в целом, по коду программы я правильно все делаю? Или может быть есть какой либо более продвинутый вариант работы с ацп?
09.10.2010 21:24:53
Когда я говорил о проблемах подключения, то  подразумевал проблему сквозных токов, объяснённую в руководстве http://www.lcard.ru/download/e20_10_users_guide.pdf
В упомянутых Вами случаях подключения такая ситуация вполне может быть.
Приведу пример. Вопиющим случаем является, например, соединение ЗАЗЕМЛЁННОГО источника сигнала с E20-10, который подключен через USB к НЕЗАЗЕМЛЁННОМУ компьютеру (например, к розетке без заземления). В этом случае весь ток заземления компьютера напрямую потечёт через кабель USB и насквозь через E20-10. Ни USB, ни E20-10 на такой экстрим не рассчитаны и имеют право сбоить, несмотря даже на гениально написанный программный код. Если с физически отсоединёнными  сигнальными разъёмами (кроме USB и питания) сбор данных идёт без проблем, а с подсоединёнными разъёмами USB-устройство "E20-10" теряет система (это можно видеть, если окно Диспетчера устройств всё время держать на виду), то программа вообще не причём! - эта проблема сквозных токов, которую нужно решать заземлением источников сигналов и компьютера в одну точку. Замечу, что в приведённом мною примере можно не только USB-контроллер компьютера подвесить на аппаратном уровне (поможет только перезагрузка), но и вообще пожечь USB-порт компьютера!
09.10.2010 21:40:34
<<реальный сигнал представляет собой дифференциальный выход усилителя>>
- Это не относится к заявленной Вами проблеме, однако замечу, что дифференциальный выход усилителя невозможно напрямую корректно соединить со входом "c общей землёй" E20-10 (без использования каких-либо дополнительных устройств согласования).
Антон
09.10.2010 21:46:21
спасибо за подробные ответы! Попробую для начала  поиграть с заземлением...
Антон
13.10.2010 20:11:14
а как можно с помощью библиотеки L-Comp включать/отключать входной ток для E20-10 rev.B?
13.10.2010 20:26:09
Антон. По  L-Comp завтра программисты ответят. Заземление решило Вашу проблему?
Антон
13.10.2010 21:30:01
Вообще говоря не решило.... я провел кой какие исследования по работе программы и вобщем получил следующие результаты:
1) E20-10 rev.B + сигнал без заземления + LGraph2=все нормально работает без сбоев
2) E20-10 rev.A + сигнал без заземления + моя программа=все нормально работает без сбоев
3) E20-10 rev.B + сигнал с заземлением + моя программа=картина такая же как и без заземления, т.е. сбои при работе по таймеру
поэтому я хочу попробовать последовать рекомендации, приведенной в руководстве и включить входной ток
13.10.2010 23:05:00
Антон.
1. При сбоях устройство "E20-10" исчезает в Диспетчере устройств или приобретает статус ошибки?
Если устройство всегда присутствует в системе даже при сбоях, то, то скорее, всего проблема в программе верхнего уровня.
2. Если формально сравнивать Ваши случаи 1) и 3), то проблема в Вашей программе.
3. При чём тут входной ток, и каким образом он может повлиять на сбои? Приведите № пункта руководства.
14.10.2010 10:44:25
Все что можно задать в Lcomp описано в справке к библиотеке в описании структуры ADC_PAR_1 в ее применимости для E20-10
Антон
14.10.2010 19:36:51
1) При сбоях устройство присутствует в системе. статус ошибки тоже не приобретает. Когда я закрываю мою программу, то при новом ее открытии устройство нормально определяется. При сбое программа просто не может дождаться прихода очередной партии данных из АЦП. Т.е. зависает на строчке
2) Формально я понимаю, что весьма вероятно что ошибка у меня, но почему с  E20-10 rev. A все нормально работает? Ведь отличие в моей программе только в том,что я ему подсовываю другой файл прошивки ПЛИС.
3) Решение о подключении входного тока мы приняли,когда почитали с нашим электронщиком пункт руководства 6.5.4. Подключение входа АЦП.
4) Из ответа вашего программиста я правильно понял, что средствами LComp входной ток подключить нельзя?
14.10.2010 20:10:31
1) Это означает, что коннект на уровне интерфейса USB не исчезает.
2) E20-10 rev.B более функционально наcыщена по сравнению с rev.А, хотя совместимость снизу вверх должна остаться.
3) Вам показалось. В п. 6.5.4 даже намёка нет на то, что включение-выключение микроамперного входного тока как-то может повлиять на устойчивость к сбоям в работе устройства.
15.10.2010 08:08:01
А с LGraph2  точно все работает нормально при тех же параметрах ввода, что и в Вашей программе? LGraph2 получает данные точно также как сделано у Вас через lcomp.
Антон
16.10.2010 21:55:11
В LGraph2 я ставил такие же настройки как и меня в программе, единственное я не уверен, правильно ли я задавал длину выборки. Я это делал, задавая длительность 0.2 секунды в окне параметров.
